Seems like your list of cars are designed for right hand drive, which might explain why volume controls are on the left, vs cars designed for left hand drive. If I were to drive one of those cars, I'd be complaining about the radio controls being on the "wrong side" because of what aim used to. Much like the discussion about the auto-stick manual shift directionIt wouldn't surprise me if all FCA/Stellanis vehicles put the volume on the right. A Chrysler I had for a bit had the same buttons as Ram.
My experience with cars has been I have driven include Mazda, Toyota/Lexus, Subaru, Nissan/Infiniti, BMW, VW, Kia, Hyundai, & Honda/Acura. They were all on the left. Heck, it seems all Japanese and Korean cars have the volume on the left now that I think of it.
Yes, it works with the MFT without issue.Do you know if the bed extenders work on the MFT? Great looking truck BTW
What pedals are those?
Great! Thank you!Yes, it works with the MFT without issue.
Do you have part numbers for the bed extender parts. Apparently they will work on a MFT.Bed extender parts installed and a pic of the tint job. Front matched to the back and 70% on the windshield.
You have to drill into the bed for installation, correct?Do you have part numbers for the bed extender parts. Apparently they will work on a MFT.
EDIT: Nevermind, found on Amazon
You may be right. At one point I remember someone saying the threaded inserts were there but the hardware isn't provided. That may of been the case with previous models and has changed for the 21s. IDK Most likely I will not drill in the bed! Probably will not use it in that configuration much anyway.You have to drill into the bed for installation, correct?
I just caught that you have ramboxes. I do not believe that you have to drill for that one, if you are using the included divider as a extender. I was thinking about buying an aftermarket extender because I really need a long bed, but I don’t want to drill into my truck. I’m sure it will be fine, but I’m just kind of weird about stuff like thatYou may be right. At one point I remember someone saying the threaded inserts were there but the hardware isn't provided. That may of been the case with previous models and has changed for the 21s. IDK Most likely I will not drill in the bed! Probably will not use it in that configuration much anyway.
Don’t blame you!! If I have to drill I’ll just go without!! Hopefully it will work without drilling!I just caught that you have ramboxes. I do not believe that you have to drill for that one, if you are using the included divider as a extender. I was thinking about buying an aftermarket extender because I really need a long bed, but I don’t want to drill into my truck. I’m sure it will be fine, but I’m just kind of weird about stuff like that
Pedals look good. Are they the Mopar GT ones...or the Amazon ones? I was thinking about the Amazon route until I saw the GT pedals.
Thank youI’m into concave wheels right now, but if I went for a less aggressive wheel, I’d absolutely do what you did. That looks incredible
They were Amazon ones, I wasn’t sure at first but I’ve had them a week and I’m happy with them so far.Pedals look good. Are they the Mopar GT ones...or the Amazon ones? I was thinking about the Amazon route until I saw the GT pedals.
Do you know if they put the threaded inserts in the bed on 22 models or do if you have to drill into the bed?Yes, it works with the MFT without issue.
I want the GT or limited anniversary edition ones tooPedals look good. Are they the Mopar GT ones...or the Amazon ones? I was thinking about the Amazon route until I saw the GT pedals.
The holes are there, you just need to install the inserts. This is for all trucks without the BUG option. Do a search on here and there are links to the inserts.Do you know if they put the threaded inserts in the bed on 22 models or do if you have to drill into the bed?
How much from the dealerPicked it up from the detailer after ceramic coating. View attachment 117028
I had it done at a detail shop. $1600How much from the dealer
Are the holes threaded? I found the studs to bolt in as long as the holes are already there and threaded.The holes are there, you just need to install the inserts. This is for all trucks without the BUG option. Do a search on here and there are links to the insert
