I don’t know if it’s icing up but it’s hard to open the latch when it’s like 35 and below.. takes me ten minutes to almost break it open lots of force.. seems like the locking latch is locking and not opening and can hardly hear it unlocking. No problems when it’s above 50You probably need to be more specific. Are you saying that it's icing up and is tough to get it to move, but then it goes down like normal? Are you saying that it initially moves just fine but it is hard/slow to get it to complete the process of opening? Are you saying that the latch isn't releasing?
It's been plenty cold here in Minnesota lately - lots of -20 mornings where it only gets into the negative single digits during the day - and mine seems to open just fine. I get mine washed often so the only problems I ever have is with a little ice. After a wash, I usually park and then go back outside 10-15 minutes later to open all of the doors and break the ice.
 I guess the ice thawed, and since the button had activated that morning, it was just ready to release it as soon as the ice thawed.
   I guess the ice thawed, and since the button had activated that morning, it was just ready to release it as soon as the ice thawed.Sounds like my exact issue. I'll give that a try. Thanks!I had a problem with my 2019 Ram tailgate that intermittently could not be opened unless I gave the tailgate a hard push towards the cab. The dealer tried lubricating the latches and it did not work. After talking to Ram they had me take it to the body shop to adjust the knobs that the tailgate laches lock onto. It took the body shop 10 minutes while I waited to adjust the knobs and the tailgate has worked perfectly since the adjustment.
