Under Hood Light 2021 Ram 1500 Laramie DT
Dcsnet
Has anyone installed the under hood light Mopar part # 68488399AB on their 2021 Ram 1500DT Laramie? I cannot find any pictures or documents on where it gets routed and mounted.
Thanks
Don
RebelWraith
Polymath
Montclair, Va.
Thanks
Don
That's just the harness, you would need the lamp which is part number 68444287AA. Here is a picture of the harness:
These parts are listed for 2021-22 Ram TRX. Not sure if the attachment points are the same on the other hoods like the TRX hood.
Dcsnet
Thanks. I do have the light as well but I just can’t figure where it gets routed mounted and where it plugs in. I checked a few Mopar parts sites with my VIN and it says these parts do fit my vehicle.
RebelWraith
Polymath
Montclair, Va.
Did you check with a dealer? The part sites aren't always accurate. These are listed for the TRX and not other Ram 1500s as far as I can tell. That's probably why there isn't a receptacle connection for it. It would be nice if it does connect.
Dcsnet
It was described as the under hood light harness but I am going to try and stop at the dealer today and see what they say. Thanks for the replies.
Don
ferraiolo1
North Central PA
Dcsnet
yeah thats what they are talking about. the "underhood lighting" is the 3 amber lights in the "performance hood" on the TRX
Ah. I got it. I think you guys are correct because it looks like there is more than one connector not just one on either end.
Rbohno
That looks like the wiring harness for the 3 hood scoop lights on the TRX. There are 4 tiny wires in the harness 3 grounds and one hot. If you can’t find a plug just tie into the drl’s or maybe fuse #11.
Cesar592
could be urged on a limited grill to make it look more oem
