Rain Sensing Wipers (Not equipped but have the part)
buckeye2019
Does anyone have the alphobd settings needed to turn on the auto high beams aka smart beams. That was discussed in here around page 4-5. thanks
mike_ct
easiest way to add them, would be to replace your rearview m mirror with a "smart beam" mirror
buckeye2019
ok, well that was easy did mine last night everything is working fine but it isn't showing up on my Uconnect settings. I let the truck sit over night and checked this morning and still not there.
How long does this take?
vincentw56
Should be there now. Check the settings in AlfaODB again.
buckeye2019
vincetw56 thanks for the response, but can you confirm exactly what settings just so I can make sure I populated them correctly
vincentw56
Rain Sensor Present: Yes
Rain Sensor Module #2 Present: Yes
Humidity Rain Light Sensor Present: Yes
Rain Sensitive Wipers CSM Present: Yes
buckeye2019
It worked I got home from work today check the truck and populated I guess during the day today this is so awesome
OKRam1500
Oklahoma
Can anyone confirm that the part number listed early in this thread and in the adaptive cruise thread is wrong - 68298468AA
And I really need this part number for rain sensing wipers - 68298334AA
vincentw56
Part number 68298334AA for the sensor, and part number 68488349AA for the sensor gel pack.
TheColt69
So both of these needed to add this to our trucks? Glad I'm double checking, I just got my truck and I want to do this, as I've heard it's relatively straight forward! Along with the tailgate ajar light, but I need to get a security bypass part still... I have AlfaOBD from my 4th Gen but not the new thing needed. I sure appreciate all you guys!
vincentw56
I'd recommend replacing the gel pack too.
OKRam1500
Oklahoma
I ended up buying just the 68298334AA part. It comes with a new gel pack already attached to the sensor.
On the installation side:
I removed the old sensor, scraped the remaining old gel off the windshield, and cleaned the windshield before installing the new sensor.
Installation of the new sensor was straightforward. Unless you damage the gel pack that comes attached to the new sensor I don't see any reason that you would want or need an extra gel pack.
TheColt69
Ok! Great! Will tint effect this at all?
Jiraola
I did the upgrade and used JScan. The menu on my 8.4 showed up immediately. Not working yet but going to let it rest over night.
JScan - adaptation
Radio user setting
Rain sensitive wipers on/off
