Just picked up my new 2019 Ram 1500 Limited yesterday, so far only 3 issues
#1 while on a phone call via bluetooth if I put the volume of the uconnect system above 22 the person on the other end of a phone call hears a nonstop echo, anything below and it sounds fine for them.
#2 squeaking someplace on in the dash every time I go over a bump, ugh...
#3 If you start the truck via the keyfob while it is locked then walk up to the truck and pull the handle to open 1/2 the time it won't unlock, if you do it 2-3 times it will open.
The build date on my track is 9-18, was hoping they worked out most of the issues, guess not.
On the bright side, it is an amazing drive, so hopefully I can get these worked out and enjoy it for years to come.
I'll drop it at the dealer and see if they can sort it out.
