2019 airsuspension
Chrislmyoung
Does anyone know if theyve improved the air suspension on the 2019s ? I just ordered one and did not realize it was stock on limited trim.. I live in canada alberta and it can easily go to minus 30s for weeks i do not have a garage to park in... Kve been told its been improved amd ill be good
202snowman
5thGenRams Supporter
Rochester, NY
Can't tell you yet if it's improved but it's different according to the brochure (and I think I heard one of the Ram engineers on a video i watched say it was redesigned)
From the brochure:
Completely unique to the light-duty segment, the automatic or driver-operated
Active-LevelTM Four-Corner Air Suspension System is available on all trim levels
(except Ram HFE). The system has been modified for 2019 Ram 1500, now
with a redesigned air supply unit in a single unit to increase capability and
reduce weight. It’s also been retuned for the new, lighter-weight frame and
chassis components.
Jared B
Site admin
Vancouver B.C
They have updated it for 2019, while its still too early to tell how reliable it will be, hopefully they learned from previous issues in cold climates. Other than cold climates I haven't really heard of any issues with the outgoing air suspension.
Chrislmyoung
From the brochure:
chassis components.
I sure hope yhat it doesent freeze up in winter . i will be so choked
Chrislmyoung
I wonder if just leave it lowered all winter if that wouhld help.. Tsise it up every once in awhile lol
Slim
If you lower the air suspension it automatically raises to normal driving position at 15 mph on my 2015 Limited. I would assume it does the same on the 2019. I live in a climate that is a regular 0-32 degrees (have a few days with 40+ degree thaws) all winter and never had an issue. FWIW
Chrislmyoung
Thank you guys for the feedback.. Im hoping i dont run into any issues
2019REBEL
ON, Canada
I have it on my 2014 Outdoorsman...4 years with no problems and this year I got the "Service Air Suspension" light. They changed the lines thinking that what it was. That was done in Feb then it warmed up above -10C and I haven't had it on since. Hoping to get my 2019 Rebel before the warranty runs out in November because I know changing the lines didn't fix it. Needs a new compressor/valve block.
Spe1996
Air suspension is a generic term. I have a Grand Cherokee with the air suspension and have confirmed that the system is actually charged with nitrogen. They use nitrogen since it's dry and is more consistent with temperature swings. Assuming the system was charged correctly then there should be no moisture to freeze. I have parked outside in sub zero tens for the last 3 winters now in the Great lakes area and no problems.
Zachtank613
Hey OP I’m in the same boat pick up my 2019 rebel next week. Got the air suspension was excited then started reading about all these problems. Like you I’m hoping they have addressed the issue. I live in northern Ontario close to Manitoba border, it gets cold. I wouldn’t be happy with myself knowing you can now purchase them without the air suspension and regular coil shocks.
Do you mind if I ask where you heard they have fixed the issue? Anything to put my mind at ease.
Noubon125
Winnipeg Canada
Chris how is yours air suspension now? Live in Ca too
Noubon125
Winnipeg Canada
I am exactly in Manitoba bud and my air suspension still work fine since we have cold weather here sometimes it is -40 with winchill. And ii keep mine in normal try not adjust up or down because sometime we have ice on suspension. But overall it is work fine untill now.
Chippy
There's only a couple fan boys on this forum who prefer the steel over air. Air same ride characteristics but so much more adaptable and capable. I tow a Nautique G23 that's worth a **** ton more than my truck and some old fashioned springs without Adding helpers not gonna do it. One of the reasons went with this truck.
VaderRebel
Canada
How fast can you go in Off Road? Oh, yeah, right, 15mph. How many lift kits available for air... 1?
It's tit-for-tat. Fan boys? No, just owners with specific needs. Just like the oldtimers with bad knees that love the entry mode. Would I call them air ride fanboys? No. Just owners with specific needs.
Carry on! :cool:
S
Smashy71
Guest
Carry on! :cool:
Off road is 25mph. Can always crank it all the way up and remove the fuse. Lol
Chippy
Carry on! :cool:
I must of hit a nerve? Anyway you don’t see me being negative in the steel suspension thread. Oh yes maybe start one rather than crying the blues everywhere else. Your the one posting negativity calling things gimmicks so if you want to play carry on.
