Interior/Exterior Lights Flickering For No Reason
L a r r y
Frisco, TX
So I went out to take out the trash, and I noticed that my lights started flickering. The interior dash lights, and the DRL's. I grabbed the handle to make sure the doors were locked, grabbed the keyfob and unlocked/locked the door, waited a few minutes and it did it again. Has anyone experienced this before?
Nope never heard of this. Is your battery voltage low?
what year is your truck?
how old is your battery? Is it original?
sounds to me like a bad frame ground....
It is sitting at 14.4v while running
It is the stock battery
No etorque
that just shows the alternator is working
you need to take it to an auto store that can put a load on it and see what happens
these systems need feed back from the battery to not have any issues and if the computer sees battery fluctuation weird things will happen
I can do that.
OFF THE WALL QUESTION:
Should this be happening, even when the truck is not running?
I have recently started noticing this in my 19 as well. After I get home and turn it off the lights start flickering and the 12” screen does too. Has anyone found any solutions to this yet? I got the truck new and currently has 90k on it.
Battery going bad, bad ground connection. I would start there.
  • The following recipients could not be found: My 2019 Ram 1500 has a frayed wire under the driver seat and last night all of the dashboard and interior lights were flashing, I pulled off the road for a few hours and everything was alright afterwards. Today.
  • Please enter a valid message.
  • Please enter a valid title.
