A/C Noise ?? Very annoying
Duran
Usually noises are covered with the sound of metal barring over the stereo.
While driving about 65 against the wind with automatic A/C on i hear a faint kind whinning noise. it was comming from the A/C .
i turned all A/C off not the fans and the noise went away. Although some slipknot and slayer would solve this problem i find myself turning it diwn to be annoyed by the noise
Anyone have a clue what is causing the noise and please offer a solution rather then telling the dealer.
Does it only do it when youre driving at speed or does it do when the truck is not moving as well?
Are you saying it is coming through the speakers? Electrical interference from the fan motor? That might be a grounding issue that is tough to find.
It comes when im doing around 65 and no with the speakers off i still hear it
If you change the fan speed does the noise change too?
I might just be a little slow understanding. The AC makes a whining noise at 65 mph.
Does it matter what vent position selection you have it on? What fan speed are you on? Is it regular AC or Max? Is it set on low or a temperature setting like 68?
I mean it could be as simple as a leaf caught in the vent. A mouse jambed in the blending door (I would hope you would smell that though unless you are one of the guys with 25 Vanillaroma air fresheners in the truck).
Hahahahha no id be able to smell it and yes with ac on not sure about the only fan turned on ill check that in my commute to work. But it seems i have a uniques issue. Maybe ill make a video of it to share
what year is your truck please
My 2020 QQ BH does the same thing. Initially thought it was the front passenger side speaker and ANC on the fritz.
Highway speeds on windy days. Random timing. Can't find a situation where i can reproduce on demand. Sounds similar to someone opening the window on the highway but inside the HVAC system. Maybe a fresh air damper flying open? Fan speed has not affect. Recirculate and damper settings have no affect. Turning the HVAC system to "OFF" will stop the issue almost immediately. Return to operation and all is good till the gremlin decides to come back. Sometimes soon sometimes not
2020 laramie 1500 4x4
switch a/c to 'recirculate', and then back to normal. That fixes it for me.
I had the same experience on a trip to Big Bend, but would add that moments after the noise began I could feel a slight increase in the volume of air from the vents.
Ill def give it a try thank you sir get back to you with results in a couple hours
So even woth the ac off and fan running i still get the noise.
