Ways to achieve 1" ORG type lift
Burner_After
Arizona
Suspension is the component I know the least about on my truck. I have a big horn 4x4 without air suspension that does not have the factory ORG. I really like the way the slight 1" lift of the ORG looks and want to achieve that with mine. What would you recommend to do to get that 1" of lift all around? Could I simply add the ORG coil springs? Would bilstein 5100 series adjustable shocks I've read about on here work? Something else? I don't want anything more than an inch as I don't want to screw with the geometry too much and potentially wear out components too quickly (been there). Thanks!
cervelo15
Lehigh Valley, PA
Just my two cents, but the Bilstein route seems the most flexible. With the ORG, it’s a fixed 1”. But with the Bilsteins, you can dial in the shorter amount of lift for now, and if you wanted to go higher in the future, its already built in.
Go cheap and grab some ORG take offs from someone who did a bigger lift on their truck. Just make sure to verify they are ORG coil springs before buying
Burner_After
Arizona
Makes sense. Are the Bilsteins only adjustable in the front? Or do they make them adjustable all the way around?
Burner_After
Arizona
That's a great idea. I'll be on the lookout for newly-lifted trucks!
Only the front are adjustable. The rear you would have to use spacers or lift coils
jimothy
5thGenRams Supporter
Atlanta, GA metro
If my front Fox shocks ever come in, I’ll have ORG components (shocks and springs, front and rear) available. I’ve got the rear shocks already, but fronts are on back order everywhere. I’ll get them in January if I’m lucky, but I wonder.
