2022 b&w turnover hitch
lgb
i have a 2022 laramie 1500 6.4 beds 4 corner air i am trying to install a b&w turn over kit 1319
says it fits a 2019 to 2021 has anyone installed this on a 2022 i did not think 2022 would be different
than a 2021., any help would appreciated.
Don't know why it wouldn't fit, but just make sure to get the air lines back in place and well away from the exhaust. Installer didn't, and it cost them 5K to fix it after it melted the lines.
That’s the gooseneck right?
just got it finished, and it does fit, took a little time but it fit really nice, and yes the air lines and wire harness end up kinda close to exhaust
pipe so i will have to wrap them with some exhaust tape, the way it is set up you really cannot reroute them with out cutting them
and that is not an option
Can you post some pictures? I’ve been looking into doing this myself
pic of 2022 laramie with b&w 1319 turn over hitch installed. go to e-trailer there is a video of an install on a 2019
really helpful. left side wire & air lines are going to be problem keeping away from exhaust its about 2 inches away
i might try removing the passenger side bracket and try to go up on top of the air shock tower, if not than its going
to be asbestos or some kind of heat resistant insulation
Awesome! What do you plan on towing with it?
23ft nash fifth wheel 7000lbs, using the anderson utimate hitch system to keep my weight down plus easy to handle 35lbs
