OhGreatExhalted1
- Jan 1, 2021
OK, maybe "Interior" is not quite right, if this is in the wrong place, please move.
2019 Ram.
My steering wheel is loose. If I grab it and try to rock it.
If you imagine that the wheel is loose on the shaft, that is what it feels like. No slack in the steering, but the steering wheel rocks like a dinner plate on a table.
i popped the airbag out to see, I found the entire wheel and shaft rocking back and forth. Not a lot, but enough to get my attention.
The wheel is tight on the shaft. Yes, the tilt mechanism in locked down tight.
I look at parts breakdown and see that the first part of the steering shaft is maybe 8 inches long and then goes into the tilt mechanism. It would be the first shaft that is loose.
Anyone have a similar experience? Do they ALL flop around like mine does?
2019 Ram.
