Map Update woes
Longball
The Nav system on my 2019 1500 has stopped functioning accurately. It shows im about 200 miles away in a forest when I am at home lol. The compass has also gone off calibration.
I got an email from Uconnect last week saying there is a map update available. Part of the update process is to get the application version that is supposedly found by holding down the drivers side temp, and front defrost buttons simutainously. Nothing happens when I do. Ive tried with ignition on, accy, and off. Anybody successfully updated this way? Also, how much $ was the map?
Thanks!
Sascwatch
On the 12” uconnect you have to hold the two outermost icons on the bottom of the screen for quite a while before the menu will appear.
I’m not sure which uconnect screen you have, but you may need to hold the buttons longer. This can be done with the engine running, and most likely with it off in accessory.
Longball
I have the 8.4 screen and Im using the physical buttons. Maybe I need to use the ones on the screen? Bet that's it! I'll try that.
