You’ll probably have to use a long flat blade screwdriver to open the doors up to get the tube out. There is a funnel under your passenger side seat that is for when you have to fill up with a jerry can or when you add fuel injector cleaner.
Glad you got it out, there is a second flap in the neck as you now know. It’s there because its a cap less design apparently. If you’re filling from a can or something with a tube like that use the funnel from the truck. It’s a white plastic tube that’s with the jack and lug wrench under the passenger seat and is designed to open both flaps so you can fill from jerrycans safely.Finally got it out had insert screwdriver through tube
Ah, so that’s what that is for. Found myself covered in Seafoam at a gas station because I didn’t depress the second flap when I poured it in. Ended up borrowing a pen from the gas station attendant to hold that flap down while I poured.Glad you got it out, there is a second flap in the neck as you now know. It’s there because its a cap less design apparently. If you’re filling from a can or something with a tube like that use the funnel from the truck. It’s a white plastic tube that’s with the jack and lug wrench under the passenger seat and is designed to open both flaps so you can fill from jerrycans safely.
Yeah I leaned about it the hard way too, seems like something a dealership should mentio along with a couple other quirks but mine didn’t show me squat.Ah, so that’s what that is for. Found myself covered in Seafoam at a gas station because I didn’t depress the second flap when I poured it in. Ended up borrowing a pen from the gas station attendant to hold that flap down while I poured.
