Adjusting windshield washer spray pattern
gpbst3
The lower left corner of my windshield never gets enough washer fluid spray. It does not matter how long I hold the spray button. Is there a way to adjust the spray pattern?
I have the exact same issue, just haven't gotten around to fixing it yet.
Take a pin and stick it in the nozzle opening and gently adjust it a tad down and to the left.
I've had luck doing this with many vehicles over the years.
Reviving this oldie because mine on a new to me '22 are aimed pretty awful as well. They don't even hit until middle window.
Replacements can be bought here for around $15 each for the ones on the underside of my hood, but I'm going to jab a knife in there in the bottom left corners and hope it opens it up just enough to spritz the bottom sections of the windshield. Worked in the past, but I miss the ones you can just turn and aim manually and a lot of truck use this under hood setup now to which I've never seen those sorts of nozzles for.
