headlight fuse for ambient lighting?
djevox
VP of Creative Thinking
MD
it looks like the description for that says overhead console and heads up display, switch 911, switch assist, or maybe im looking at an incorrect chart?
You are probably correct, I’m going off of memory since I’m not in front of a computer anymore. Earlier today, I was messing around under the steering column of my truck and that is the two fuse slots are used for the parking feature on my dash cams.
firemedic10584
Central Florida
As I stated in the other thread - simply tapping your power wire for your LED lights onto the headlight power wire will accomplish what you're wanting. They will only come on when your headlights kick on. Very easy to do. I don't believe there is a headlight fuse on the interior fuse box, but I could be wrong.
djevox
MD
It’s probably not that simple. There are separate wiring for low and high beam, meaning he’ll lose interior ambient lighting when he switches to high beam or not have it when he switches to low beam. Some food for thought.
Richard320
May I suggest keeping them on a separate circuit for ease of wiring, but use one of the homelink buttons for a clean look? Check out this writeup. It wasn't mine, but I really like the idea.
firemedic10584
Central Florida
What? That made no sense lol. The low beams aren't turning off when you activate your high beams? Don't tap into the high beam power wire, but I don't believe that is at the headlight knob.
djevox
MD
Take a look at the wiring diagram, and it’s not common for low and high beams to be on at the same time.
firemedic10584
Central Florida
IDK how common it is, I've never seen a vehicle that shuts off the low beams when you activate the high beams. Our trucks certainly do not do that. The fog lights, yes. Those are cut off when you hit the high beams. Either way - I'm just telling you what will work. Whether you want to go your own route and make it more complicated, that's up to you lol
djevox
MD
@bnh105 Firemedic’s passive-aggressiveness aside, check your truck to see whether low and high beam stay on. I don’t have access to a limited to check if there’s low beam dropout. If they do stay on, you’re good to tap into those low beam wires, but if it were me, I’d still check the lo beam voltage to see if it stays at 12v+ DC when high beams turn on.
I also don’t know if your DRL‘s will run the low beam (mine do on the laramie). If so, you’ll have to take that into account.
firemedic10584
Central Florida
I've worked on a few limiteds, the low beams did not turn off when the high beams were activated. This was on a 2020.
J-barcarp
54 year old teenager
Just North of Detroit
i checked mine in a store window last night.
lows stayed on but dimmed just a bit.
fogs stayed on
oddly, i could not get the main low beams to turn off at all.
even if i turned the lights to off.
kapinallinen2
5thGenRams Supporter
Southern Maryland.
With my LED headlights the low beams stay on when I turn on the highs, best headlights I have ever experienced.
As far as tapping into some fuse, you all might be out of luck, from what I can tell they are controlled by the BCM :( So it would be necessary to tap straight into the head lights wiring.
This is the basic lights diag. LEDs are the same exept they are called out as a circuit board.
firemedic10584
Central Florida
You are correct - they are controlled through the BCM.
