Hello All,
I put on some RECON headlights on our 2020 Ram 1500. I want the OLED to run as my DRLs without me having to change it to parking during the day. I was hoping this change could be made with the Alpha OBD but from talking to some guys that use that quite a bit, parking is not an option under what you want to turn on when you turn on your DRLs.
With that said I noticed that some folks are doing a Wire Fuse Tap to their ignition fuse which will turn them on anytime the ignition is turned on.
Has anyone had any luck with this and have any input? I did see a video of headlight revolution on you tube where they did this with a Toyota Tundra but obviously they had the wiring kit made for that.
Also if I try this does anyone know the color of the parking light wire?
Thanks for any input.
