Wheels spacers?
Jack.
Considering making my stance a bit more aggressive but after a tons of research it seems like most people think spacers aren't worth it (bad mpg, rougher rides, can't drive fast etc). I'm not looking for anything crazy just as long as it sticks out past the fender by a little bit and I'll be happy.
With that being said do you guys think it's worth it to grab spacers ? ☠☠
djevox
VP of Creative Thinking
MD
Don’t tow with it!!!!!
J/K, that was just a ruffle some feathers. I say yes, get some quality spacers. By quality, I mean Bora, spidertrax, etc., not guangzhou limited llc specials on ebay.
I’m making light of China, but they dont produce bad products if the Quality Control is good.
Jack.
Yeah I wasn't going to cheap out on the spacers, I feel like it's one.of those things where I would want a really quality ones so I don't end up dying going 90mph or something haha. I'm just worry about how much worse the ride quality would be and ofc also thinking bout mpg cuz gas been ridiculous
ekaz
There's a giant thread about wheel spacers and a couple of YouTube videos on them. Depending on what trim and wheels you have, 2" sound like they would get you the look you want. Bora makes great hubcentric spacers. Not cheap but you don't want cheap when it's holding your wheels on.
djevox
MD
I’ve run spacers from 1/2” to 2.75” and have not seen a difference from the spacers themselves (when running billet). What usually will dip your mpg a little is from high rolling resistance (i.e., wide tires, tires sticking out from side of truck, etc). Technically, spacers will always affect mpgs a little because you’re adding unsprung weight, but if you choose your spacer wisely, your mpg drop should be negligible.
Jack.
I think 1.5inch would be perfect, and yeah i been watching a lot of youtube videos on them and reading articles but it seems like theres quite a mix reception on them. Right now i got the trx rims on and 285/65/r18 falken at3w, just trying to see which brand spacers is worth it haha
ayoslickxd
i got 305/70/18 rims and 1.5 spacers front 2 inch rear i dont stick out with my fender flares .. mpg has not taken a hit with spacers added i will say im adding rims with negative offset and gonna most likey remove my spacers. just to compare
ferraiolo1
North Central PA
Bora or shifted industries are the two more quality ones.
Jack.
Would I just cop them off of Amazon?
There's probably not any benefit in going with actual wheels over hub centric spacers correct? From what I'm getting most of the negative experience people have with them are from people cheating out and not going with hub centric quality ones
ekaz
https://www.motorsport-tech.com/ for Bora. I saw a couple people mention KSP that can be had from Amazon but no idea on quality or anything.
ferraiolo1
North Central PA
No don’t just cop a set off Amazon. Then you will be one of the guys coming on here making posts about how bad spacers suck because you got a cheap set. Spacers aren’t something you cheap out on.
Buy from a reputable shop or seller
But for what a set of good ones cost. It’s usually half of what a good set of wheels with the proper offset cost. Which is what I learned.
Jack.
Im looking at the motortech website now and theyre not as bad as i though the bora 1.5 ones are going for like 70 bucks? i was expecting at least minimally 150 per.
ekaz
The price is per spacer, not pair.
ekaz
I just ordered a set of 1" spacers and 1.25" spacers, came out to $267 shipped. There's at least a few week backlog between order and delivery.
ferraiolo1
North Central PA
Good chance you’re going to have to cut your studs
Jack.
Is there any ways to determine whether or not i would need to cut my studs? the wheels i currently have do have those tiny pockets for them
ekaz
Hoping there are pockets on the back of the wheels and they're deep enough to not have to cut the studs. Heck, after seeing how it looks, I maybe opt for wider or no spacers.
Jack.
These pockets here correct?
