Fogs not working…
DO82
So shortly after I replaced the halogen fog lights they turn off without warning. No codes and the dash still shows they are on. I can turn the truck off and back on and they will light up then turn off. I dont think it’s the light since both sides turn off. Im running H-11 led’s with canbus harnesses.
Wonder if there is a thermal protection somewhere heating up.
I thought the same thing but it happens at cold start. Can’t imagine it gets that hot within seconds of turning on.
I saw last night on YouTube that it is a thermal problem. The fellow added a relay for each light so the controller only saw the load of a relay coil. The heading was something like LEDs destroyed my Ram. You can check it out if so desired.
Welcome to the forum .
