Your choice in leveling kit, and would you do it again?
theblet
I really like the look @moosem I am planning on using pucks as well. Not sure if I should go with 2" or 2.5"
Whoa_Ram
Azle TX
If you tow anything I would go with the 2". Unless you want a little bit more height go with the 2.5" but it will be pretty much level so you might have to add a spacer in the rear.
  • Like
Reactions: Rau
BowersFJ
I wouldn’t go much beyond 2” with the pucks ….. To get beyond the 2”, you can add Bil 5100’s …. There is a thread on here with a guy who did the Readylift 2”, which is pucks and UCA’s, and then added Bils at 1.3” clip #4 position …. Even with just pucks, UCA’s are a good idea …. Check the thread out …. 3.3”F and 2”R is a perfect stance that slides in a 7’ garage door …. That’ll be the route I go when my 22 order finally shows up
djevox
VP of Creative Thinking
MD
I’m having a really hard time deciding if I should do the motofab 3” front/ 1” rear with my readylift UCA’s instead of the 2” level.
  • Like
Reactions: Rau
BowersFJ
JMO, but no way I would do a 3” top spacer
djevox
MD
Looks like 5100s are back ordered at all the places that seem legitimate.
djevox
MD
I ended up ordering the Eibach pro-truck kit because of the reason I mentioned in the above quote and the fact that I like all the Eibach lowering springs and shocks I’ve tried so far. I’ve abandoned the spacer idea.
BowersFJ
I got till Feb when my wagon shows up …. I’ll get em ordered now
djevox
MD
My 2" motofab give me a 1/4" of rake 2.5 would be nose high and be obvious with weight in the bed
Wait, people use the bed? It’s not just for good looks!?!
BowersFJ
Jesus people ….1”-1-1/2” of rake, or you look Cali drag *** low …. And that’s just stupid
Whoa_Ram
Azle TX
You say that now… Then you’re a few beers in and order $1200 worth of suspension and you’re blaming @Whoa_Ram for it.
HAHA it's so hard to keep things stock while there are so many great things you can do to it. Once you get your shock kit and give a review, I'll probably be ordering mine and blaming you LOL
