AC draining into front passenger floorboard
emptyfly1
Central Arkansas
Mine wasn't leaking, but because of all the talk about it, I put this on there.
These are 5/8"
This is exactly what I've been looking for. Thanks!
emptyfly1
Central Arkansas
We got updates...
I was able to slide a small piece of garden hose over the drain on the engine side of firewall and then drove the truck running errands for several hours without any leaks. I believe this has stopped the water from running back inside the cab along the bottom of the drain pipe. The simplest solution is usually the best solution.
I haven't done anything permanent to alter the vehicle in any way. I haven't taken anything apart or damaged/altered/changed or deleted anything! Just want to make that clear for any legal minds that might be lurking. ;)
firemedic10584
Central Florida
We got updates...
I guess I'm just confused as to how putting a hose or elbow on the firewall side of the drain tube fixes it? If the water is coming from inside the truck and making its way out...how does something on the end of the tube stop it from coming back inside the truck? The water has to make it out of the drain tube and down the hose or elbow to drip to the ground right? So if it doesn't make it that far and sloshes back inside, how is that fixing it?
mikeru82
5thGenRams Supporter
The Palouse
Think of the water like a line of ants. It exits out the tube, "crawls" around the bottom of the tube opening, and runs back inside the cab along the under-side of the drain tube. The surface tension of water allows it to cling to the tube in this way. Adding a hose to the drain tube prevents this from happening.
firemedic10584
Central Florida
AHhhhh I see what yall are saying now. That made more sense. I was picturing the water just going to the edge of the tube and not quite exiting the tube but instead just rolling back inside the tube back into the cab and causing the leak from there. This made better sense to me lol
Mopar_maxi
We got updates...
Try the 5/8” elbow that was posted on here and report back if it’s solved the “leak”
emptyfly1
Central Arkansas
I did order the 5/8" elbows on the Jungle website. With the EcoDiesel emissions, it's a tight fit to get one on. Right now, still running a piece of garden hose on the drain because it's got a thinner sidewall and much more pliable, especially with a little heat. Either way, the "drain extender" seemed to have fixed the problem. Thanks for the help and the elbows.
firemedic10584
Central Florida
I put a piece of wire loom with a zip tie on mine - has worked perfect ever since lol.
julianchilco
I know this is an older post but thought I’d share. Had this issue on my 4th gen. Water even leaking into the cab in passenger floor. Bought one of those skinny reusable straw cleaning brushes from the dollar store and stuck it in the ac drain on the fire wall and couldn’t believe how much water came out. Thanks everyone here for the useful tips
