2020 Rebel Rear lift options..
NewLove
Have a 2020 Rebel with Bilstein 5100 installed at clip 5. Perfectly leveled.. Question is when I load the truck up I now get some squat in the rear which I hate. Looking into lifting the rear a bit to get rid of the squat.
Should I go with ICON 1.5 rear springs or just go with a motofab spring spacer?? Not concerned about saving money, just trying not to effect the ride comfort, and do it more the right way.
I think the ICON Springs will only give me a half inch more seeing it’s a Rebel. Is this correct? If so, I’m not sure that will be enough to get rid of the squat when loaded up.
Any help appreciated! Thanks.
BowersFJ
Check out Dobinson 2” springs …. Would give you 1” lift …. They come in stock load, or an extra load version …. A guy on here has em, and said they ride great
jellis466
Missouri
i have this same issue with my Lonestar. if the 2" springs are added, will i need knew shocks as well to accommodate for the increased length?
