Phone not connecting on Bluetooth
Moosefire66
So I've had my 2019 for a couple months now with no problems, but now for some reason when I make a call, it doesn't automatically connect via blue tooth. I tried restarting the truck, un-pairing the devices and re-pairing twice with no success. I even checked the settings on the radio to make sure I didn't mess with it by accident.
Now, for full disclosure, I have a 3 year old who likes to mess with stuff, So it's fully possible that my phone is the problem not the truck. That being said, I checked the settings on my Bluetooth and everything appears to be fine. When I click on the "uconnect " option, it says audio connected, just not calls. When I click the call button, it turns itself off immediately. I'm hoping this is an easy fix, but hoping someone out there experienced this before and can help
2019 ram bighorn v-6
5 inch radio
Samsung s21 phone
The issue is you have th v6 instead of the v8
Haha, it wasn't my first choice, but I have a 3 year old and another on the way... I bought this used 4 months ago for 28k. All of the other trucks then (if you could find one) were going for much more than blue book, so I settled for this one just because it was a crew cab, which I needed for the 2 car seats to fit well in the back. Not my best decision, but got a nearly new truck for what I thought was a fair price
Here's pics too which I forgot to post
What happens when you click the toggle button on the phone screen for calls?
It just turns itself back off.
Fir whatever reason today it worked flawlessly all day. Mightve just been a glitch in the truck or my phone...
Grab your phone and try this. Go to settings > apps > Uconnect then storage and cache > clear out your storage and cache. Remove the phone from the Uconnect system on the truck. Reboot your phone. Pair everything up again and make sure the phone slider is on. Also, check your phone settings on the truck too, you could have the phone/calls option disabled on the truck.
It’s your Samsung. They are notorious for failing the BT test. OS updates screw them up and you have to wait for the updates to the update to fix
This is what I ended up doing. Didn't work at first but next time I drove it she connected right away
I'm hoping this may have fixed my issue. I went into the uConnect app settings and noticed numerous permissions were off inlcluding "phone." I will check next time I drive. Thanks in advance!
