Like this?
My 2020 Ram Limited going to the dealer tomorrow for several issues
My Ram has several issues that are on the whole truck, this is my 4th Dodge truck over the years since 1987. My truck here is a year and half old with 17000 miles, my tires are worn out,, my drivers side auto step works when it wants, my steering wheel wood insert is turning orange, both front...5thgenrams.com
Did you ever get an answer on this? Mine did the same thing and was wondering if warranty would cover it.Exactly! I wonder if it would be covered under warranty.
I disagree that it's a common issue. Seen a few people complain about it, but not enough to call it common. And it's definitely covered under the original 3/36 warranty. Beyond that you're on your ownseems to be a very common issue ! I don't think that is covered under warranty
I have a 2019 Limited and this is just starting to happen. Very weird. I have the Added Care Plus warranty and will ask if it's covered.Is anyone seeing any yellowing in their steering wheel trim piece at the 6 o'clock position? I'm not really sure what to call it, but it's the gray with while piping. Mine is starting to yellow a little bit. Anyone else?
Would you be able to provide details on removal and installation of the trim piece? I am anticipating having to buy it myself and would like to know how to remove the old and install the new.From what my service advisor said, it’s piece that can be purchased separate from the outer rim (just waiting on FCA approval) I’ve ordered the oem new wheel to swap my existing wheel trim on. The reason I want that trim piece warrantied is so I can install it on my new wheel….costs the same as the whole wheel itself.
These are the part numbers see for yourself -
Steering Wheel > 6XR982X7AA
Insert 6 o Clock > 7AW00TX7AA
**reason for all this effort**
Hate buying used cars/ trucks but with supply chain a used limited was all that was available immediately. So new interior trim it is…
For reference, a single paddle shifter on my AMG is more expensive than the entire limited wheel assembly LOL
My original warranty is up but I have an extended warranty that I got from FCA a while ago for an issue I had. I am hoping they will cover it under that warranty. I don't think it's from the sun because my truck is always parked away from the sun and I use a shade when it's facing the sun. Who knows. Maybe the heated wheel?FYI - I had mine replaced under warranty by the dealer. I can only guess that the discoloration is from the sun.
Thanks. Always worth a try. If not I'll have to buy the piece and figure out how it comes off to replace it.It's not likely to be covered under your extended warranty, but it's worth a try of course.
Just need to pull it out, it just snaps in. Be prepared to pay about $175 for that piece.Thanks. Always worth a try. If not I'll have to buy the piece and figure out how it comes off to replace it.
I figured it would be expensive. Mine is pretty bad and irritates me so I'll suck it up if the dealer won't warranty it. Thanks for the info.Just need to pull it out, it just snaps in. Be prepared to pay about $175 for that piece.
