Finally got around to installing my leveling kit that I put together. Total parts used:
ReadyLift 2” leveling kit 66-1921
Bilstein 5100 adjustable front shocks : 2x24-300872
Bilstein 5100 rear shocks 2x24-233354
Icon rear lift springs
Overall installation difficulty was as expected. A few nuts had to soak to get off (strut) but overall no issues. One issue I did run into was on the top strut nut for the rear shocks. The nut was manufactured incorrectly. It was drilled off center rendering it useless. We tried to tap the existing nut to match the new thread but the tap broke most likely due to the strength of the steel of this nut. I cut a 12x1.5 lug nut in half to fit for now and contacted Bilstein for a replacement.
I have no pre measurements for this to compare to though. I was installing a tranbrake on a friends 2019 C7 while another of my friends started disassembling my truck. After measurements left me with 275-60/20r tires at 40” fender to ground rear and 39.25” fender to ground front measurement.
Overall impressions: The ride is noticeably stiffer in a positive way. Some small bumps are felt more but the absorption and rebound of the medium to large bumps os significantly better. Smooth ride remained the same, overall if the factory ride was considered a 10/10 for comfort, I would give this a 9/10 still. But due to the improvement over medium to large bumps it was worth the purchase.
The rear feels significantly better. Less roll, more noticeable control of steering and turns, better ride. I noticed that the rear comfort improved on all driving conditions. The body roll of the truck is significantly reduced
I would not change anything for this installation at this point. I will be adding tires sometime between now and spring also and will report back. Planned purchase for this is Toyo AT3 35x11.5x20.
