Angel Phoenix said... "Thanks for clarifying. I saw some people in other forums/YouTube comment sections insisting that it accounted for a 150lbs driver, and some that it included 300lbs of people total. Doesn't make a whole lot of sense to do that cause you have no idea how much drivers/passengers will weight but I saw it enough times that I wanted to check here.
Until the "adoption" of the Automotive Engineer standard, that only happened around four years ago, understanding this was impossible as each manufacturer would do their own thing usually tweaking things toward their larger numbers for "marketing" purposes. When you bought a vehicle for towing you had to carefully read how they defined payload as many would do things like use an arbitrary number for the weight of a person(s) as part of the calculation.
Apparently a conflict existed between "Marketing Pukes" and "Engineering Nerds" over this with the marketing and "Bean Counters" winning over the engineers. The Engineers responded by using hard numbers in a well thought out formula that was based upon a consistent and logical set of tests and trials to counter the "Mo Money" argument of the marketing and bean counting pukes. At some point the Lawyers stepped in after lawsuits I am sure and said, hey wait a minute... We just paid someone millions of dollars because they couldn't understand our definition of payload. And then the actuarials stepped in and noted that even with the deaths and lawsuits, we still make more money than we pay out in settlements and so back and forth it went until finally one CEO (probably a former engineer) said, this is stupid, let's use the standard to define. It was Toyota, by the way and since they were already at the bottom of the pack in sales, what did they have to lose... He said, we will use a counter marketing argument tied to our quality and dedication to our customers...  Well, at that point the dam must have broken and the other manufacturers began to fall into place and we reached the point we are at today where, I believe, all of them use the standard... And for the engineers, a rare win occurred... As customers, well, we don't matter anyway.
