Lets see those aftermarket wheels!!
I have a 2021 1500 Limited and I’m wondering if it will take 18 inch rims 7-9.5” wide so I can get the 33” nitto ridge grapplers tires with a larger side wall as I plan on taking this off road for over landing. I can’t find any information if an 18 inch will will interfere with the calipers. Given the air lift I don’t wish to do any lifts to avoid problems with the warranty. I would appreciate any information on this. Thank you.
I am looking at the following three tires but I guess the rim size would be more important?
The 265/65R18 Nitto Ridge Grappler has a diameter of 31.77", a width of 10.71", mounts on a 18" rim and has 654 revolutions per mile. It weighs 52.8 lbs, has a max load of 3305/3000 lbs, a maximum air pressure of 80 psi, a tread depth of 16.4/32" and should be used on a rim width of 7.5-9.5".
or this one:
The 275/70R18 Nitto Ridge Grappler has a diameter of 33.19", a width of 10.98", mounts on a 18" rim and has 626 revolutions per mile. It weighs 58.5 lbs, has a max load of 3640/3305 lbs, a maximum air pressure of 80 psi, a tread depth of 16.4/32" and should be used on a rim width of 7-9”.
or this one:
The 285/70R18 Nitto Ridge Grappler has a diameter of 33.98", a width of 11.5", mounts on a 18" rim and has 612 revolutions per mile. It weighs 59.9 lbs, has a max load of 3860/3525 lbs, a maximum air pressure of 80 psi, a tread depth of 16.4/32" and should be used on a rim width of 7.5-9.5".
Thank you! The New Guy…
or this one:
or this one:
Just make sure to test fit. I've had 2 sets of 18's. The 1st set fit fine with no issues. My second and current set is a bit too close to the caliper and knocks off wheel weights. As far as tire sizes I went with LT305/65 18
I just bought a 21 Night Train and was hoping to find more pics of black wheels. Anyone have any new pictures to add?
Looking to put some 20x10s on my truck. Not sure what off set to go with. Will be running 33 inch tires. eager to see everyones set up
These are 20x10s running Toyo 305’s.
I needed a 1 inch level and trimming the wheel liners.
Those are sharp, that is the style I am looking for. What kind of wheel is that and off set?
Fuel Heater 20x9, +1 offset. It doesn't really show in the pics but the polished section is actually smoke tinted, so the wheels are black and greyIMG_8366.JPGIMG_8364.JPG
