Right Frontal Acceleration Sensor help
Synergy26
Can someone point me to the correct location for this sensor? Need help finding it! Thank you
Quote: "A front sensor is located on the back of each vertical member of the radiator support below the inboard side of the
headlamp housing and have a side acceleration type sensor located near the base of each inner B-pillar and the middle of
each inner C-pillar, concealed behind the interior trim.
I'm getting code B0095 via alfaobd and says "right frontal acceleration sensor" after pulling dash out to check HVAC housing seal. Everything is plugged back in properly but the "service airbag" won't go away and I can't understand why. Do you have any idea? I didn't touch any of these sensors. Where did you get these diagrams from? If I unplugged something before the battery was unplugged would it trip it so I couldn't reset it? Thank you!
