Rlaf75
Takes potshots
- Jul 9, 2021
I maintain a bunch of fleet vehicles that use thin rubber mats in the cargo area. The mats have a textured pattern that helps keep the cargo from sliding around but still manageable enough to pull out of the cargo area. I use one in the bed of my Ram over the spray in bed liner. What ends up happening is if the item is a little on the heavy side the mat will come out with the item when pulling it out of the bed. In that case the mat is used as a slide over the bed liner. It works pretty good
