Rear Cluck sound?
Sixntwo
Houston
2019 V6 Laramie 4x4
31k
At low rpm sometimes I feel a clucking sound coming from the rear….. I am assuming its the transmission but not sure
maybe driveshaft?
anyone else experiencing this?
I did see a few threads recently about the rear end differential fluid being low from the factory and causing some noise... maybe you're experiencing this now too...
Thank you for the reply…. its getting more often so l need unfortunately head to the dealership
If it's 7nder warranty that's what I would do. If not I'd check the level of the rear end. If low I'd change it,vandbgobtrom there. Good luck and let us know what the problem is
