Tires fitting
Thr33BlindMice
NorCal
Im clueless. Sorry.
My 2019 bighorn stock wheels/tires 275/65/18.
Spot a toyo set locally 265/70/18, will these fit???
thanks.
jimothy
5thGenRams Supporter
Atlanta, GA metro
265/70R18 is 32.6” tall, 10.4” wide.
275/65R18 is 32.1” tall, 10.8” wide.
They should fit fine; you’re a bit taller, and a bit narrower. Personally, I like a tire that’s a bit wider than stock, rather than narrower, so I’d look at 285 or 295 before 265. (I run 305/60R18, which is the same height as stock, but 1.2” wider; these are probably too wide for stock wheels).
(265 refers to the width of the tire cross section in millimeters; divide by 25.4 to get inches. The second number is the aspect ratio, or the ratio of sidewall to width. Multiple the width in inches by the second and divide by 100 to get the sidewall height. Double that and add the third number, the wheel diameter, to get the total height).
(265 / 25.4 * 70 / 100 * 2) + 18 = 32.6”
Thr33BlindMice
NorCal
Thank you
