Need Tire Advice 😬😬
Duran
I have a 2020 1500 laramie. I added a 2.5 levelimg kit. On 20" rims.
Question is. Im looking to buy nitto ridge grapplers. 33 /12.4 on 20s. Will the fit in my wells. Without rub.
Anyone have this set up . Waiting to pull the trigger.
They might rub depending on what offset you are running. If you have a + offset, it's likely you will get some rubbing. I have 305/55R20 Ridge Grapplers which are 33.2x12". I have them mounted on a -12 offset wheel and I have no rubbing.
I bought the non-LT version because they are 15lbs lighter per tire. They ride better and you don't take such a big mpg hit.
I was gonna throw in a 1.5 in spacer for the wheels cause i wanna keep my stock rims. Where did you get your tires from. Real truck doesnt offer the non lt version
I bought my tires from Discount but Custom Offsets has them too.
