Gruy7th
- Mar 23, 2021
I’ve done a ton of research regarding replacement tires for the factory 22 inch rims. After much debate I pulled the trigger on a set of Mickey Thompson Baja Boss AT 33x12.50R22. I just had them installed and I’m here to tell you they fit without any clearance issues with the control arm. There is a slight rub at full lock in reverse on the inner fender liner. This was a super easy fix by pushing it back and out of the way. Here are some pictures that may help anyone else looking to up grade their tires.
