Added the AJT radio/climate knobs to complete the set with the shift knob.
Added some eBay OEM style fender flares. Fitment is pretty good. Added 3M double side foam tape to the edges to keep them rubbing the paint off.
Where did you get those and how much did they run you
I just did a quick search on the Internet and it was easy to find.
Put in the Mopar utility rails, the 16 rivnuts were a pain, but the rest was easy.
I want to add this but I am not sure if it would work with my retrax powertrax pro xr cover. How sturdy are the tiedown points?
They seem pretty sturdy, they are rated for 250lbs each which I think is about standard.
Did my first oil change since installing my fumoto valve that is supposed to make oil changes easier and less mess. I might have to get a different drain pan because as soon as the oil hit the drain pan, it started splattering everywhere, all over my head and faces almost a 2' radius around the pan. So actually made more of a mess with the oil than just letting it hit sway bar. Finally got the pan centered with the stream so it was hitting the hole in middle and it stopped splattering. Thinking a screen on top or something to reduce splatter, or will have to get a hose that fits over the nipple on valve so it goes straight into drain pan. It just doesn't "flow" out of the valve smooth enough. Waiting on engine to cool down a little more before taking filter off as I use the larger older Hemi filter so take a little more to get it out
Omg
, please tell me you have a video!?!
  • Nels
