Noisy Rear End After Lift
BONES55
I have the Rough Country 3.5 inch lift on my RWD 1500. I wanted a little down rake back so I removed the 1 inch top rear spring spacers and installed aluminum 2.5 inch spacers that sit on the rear axle and fit to the bottom of my tear springs. I love the look and ride but now I'm hearing a lot of creaking back there at low speeds, forward and reverse. Especially in the morning. It's not as bad in the afternoon in the heat of the day. Are the spacers slightly shifting or are all my bushings back there the problem, since all the sway bars and such are now sitting at different angles. Has anyone had this issue. Resolutions? Truck only has 6,000 miles on it
Maybe try adding a mopar rubber spring isolator between the spring and spacer …. 68273964AB
That top spacer isn't a spacer. Its an isolator. P/N 68273964ab Its gonna make noise if you remove it.
Right …. I was saying he could try adding another “isolator” between the spring and spacer to get rid of metal to metal contact …. Spring-Isolator-Spacer-Isolator …. Just a thought
I think, if it's the spacer, then the problem is from the spacer slipping on 5he axle perch but Idk. The fact that I can barely hear it later in the day when it's hot out makes me think that it's all of my bushings back there. And that the heat loosens them up a little. Maybe I can try lubricating them some how.
All the bushings in a 6k mile truck? The isolator is made from delrin or a similar product. Its plastic. It isolates the coil from the perch and locates the coil roughly centered. Without it the coil has room to shift and will squeak.
No. You removed a rubber isolation piece, not a lift spacer. It needs to go back in or you'll continue to have metal on metal.
