Ram Box divider/extender handle and pin.
Rays
Ram Box divider/extender handle and pin. Just bought a 2021 Laramie with ram Box and dealer claims it doesn't come with the handle and pin ?
Welcome. Are you talking about the parts needed to use the divider as a bed extender? My dealer told me that they stopped including them on 2019 and up. You can still install them yourself. Look at this thread.
The ability to use the Truck Bed Cargo Divider that comes in the Bed Utility Group, as a bed extender, does not exist for the DT Platform RAM 1500. The Truck Bed Cargo Divider can only be used to separate parts of the bed on the DT Platform.
On the DS Platform RAM 1500 Classic, the RamBox Cargo Management System comes with the Truck Bed Cargo Divider/Extender; the Handle/Swivel Release 68054996AA; the Grommit/Pivot Joint 68054997AB; and the Left Rear Box Side End Rail 68044935AC. You are able to use the Truck Bed Cargo Divider/Extender, as a bed extender, on the DS Platform RAM 1500.
Hope this helps you. Your dealer is correct.
That first part is incorrect, per the thread @Morenar shared above. I’m one of the MANY members who own a DT with RamBoxes and the BUG, received the divider/extender (but not the pegs/releases), and either had our dealers supply the missing parts (as I did) or purchased them ourselves. So it absolutely “exists”, but FCA quietly discontinued supplying those parts (presumably due to taillight visibility regulations) after production started on the DTs. Back in 2018, I showed my dealer several brochures depicting those parts on a DT from my time of order; FCA edited those documents later to hide or remove them. But the holes are there and threaded.
I am having the same issue, how the hell are you suppose to connect it and where can you get the pins to fasten it...
Where can I buy the lock
Where can I purchase those pins or locks?
Has anyone successfully put pins in a 2021 Laramie ? Fortunately I kept my 2014 devider because my new ram didn't come with one.
Just to confirm that I ordered/received the swivel handle and pivot grommets in a week, installed them today on my 2021 Ram 1500 Limited with Crew Cab, MultiFunction tailgate & RamBox. The install was very easy, the only difficulty was getting the hole tabs (see pics) to come out clean. They required a sharp/flat tool to pry underneath, then with gentle nudging the whole tab could be pulled away from the trim whereas they could actually be spun out like a bolt. The ones that broke could be spun out from the inside using needle-nose pliers. All parts, invoice and fit are in the pics!
welp i'm sure this isn't the last time someone will post with this question. Wish we could just redirect to the linked thread and close the thread.
Same situation here. My dealer said after due to a lawsuit they do not include the fasteners for any models after 2019. Currently looking for what Bezos has to offer...
how do we turn off tail gate is open alert lol or better yet geting connected to uconnect a
