Exhaust tips
Gregory.wall
Southeast Georgia
Hey everyone. I noticed my passenger side exhaust tip hangs just a bit lower than my driver side.
Is this just from the hangar probably stretching out a little bit? I got underneath the truck cus it was annoying the crap out of me and everything seem tight.
I’m a first time truck owner so just wondering if this was normal to happen over time?
It’s hardly noticeable but it just caught my eye.....
Hey everyone. I noticed my passenger side muffler tip hangs just a bit lower than my driver side.
I've noticed that couple of days ago as well. I thought I got a bad assembler, but since both of us have passenger side hanging lower, I now wonder if it is "by design", maybe, that's a "feature"!! lol
Lol I hope it’s not a “feature”. I’m almost 100% its from the rubber hangar stretching but just wanted to know how common this actually is.
They're very easy to adjust if you're willing, no need to go to the dealer for it. There's just one bolt that you losen and you can move it to wherever you want.
Okay cool. I saw the bolt this afternoon when I was looking under the truck, didn’t mess with it though.
Does it slide up and down or something once you loosen it?
They designed it so it can be adjusted any direction you need. Kind of like a ball and socket joint, but with hallow tubes.
Jordan2929 is this the bolt you are referring to.........
Oh, and before you try to loosen them they MUST be sprayed with some type of lube (wd-40, ZEP-45, etc) otherwise they will sieze because thye're most likely stainless bolts.
Yep, have you tried adjusting it?
I have not tried yet. But it looks like it needs to come up about 1/4” to 3/8”. Probably closer to 3/8”. It’s a small amount but working with wood joints and all I need to be precise so it looks like my hobbies have carried outwards to other things.
It literally takes less time to grab a 13mm wrench and adjust the tips to your liking, than it did for you to write the above post. You could have been done by now.
No members online now.
