Toyo AT3 wheel width
TLOC
NC
Realize there is a few threads about this tire but I've decided to get a set in 33x12.5R22 or 305/45R22. Toyo wed site states approved rim width for the 305/45 is 9.5"-11.5" so is anyone running these with the factory 22x9 wheel? The 305/45 have a mileage warranty and are 10lbs lighter. Issues or thoughts from the forum? Thanks
SKT Customs
5thGenRams Vendor
5thGenRams Vendor
San Diego
The “approved rim width” basically means nothing. You’ll be 1000% fine running 9” wide wheels on them. People run 9” wide wheels on 40x15.50s & 14” wide wheels on 35x12.50s haha
paulmarsh22
Skinny rims and wide tires has always been the poor mans beadlock, you'll be fine!
Wtray
This is exactly what I am running right now, 305/45 r22 Toyo OC ATIII. No issues so far and the 10 lbs lighter is why I chose the 305/45 over the 33". I run them at 41psi.
PaulieWalnutz
Any rubbing? Do you have stock susupension?
JVS0302
Where did you find these? When I look on TireRack they are not showing this size for the ATIII
JVS0302
I couldn't find them there either. DiscountTire had them, $353/ea I think it was.
Strange , maybe supply issues? Just weird it doesn't show up at all as an available size.
pinzg35
Supply but more a distribution issue is what Discount told me. Took a couple weeks to get them shipped to Discount before I was able to get my ATIIIs installed.
Wtray
Discount Tire is where I got mine. Plus I sold them the **** Good years for $75 a piece.
JVS0302
Are these an LT tire? I am 99% street driving, rarely will go off road. Wondering if these are too aggressive and if there is something I should look at in between this and a regular street tire.
pinzg35
I believe the 305/45/22s are not an LT tire. I wanted a little more meat the then stock 45s so went 285/50/22 which are an LT tire. I will say even with the change in a thicker ply, I am really liking the ATIIIs. Yes the ride is a bit more rough, but honestly not a huge change ride quality. Just my 2 cents=)
JVS0302
Thanks for the input!
Rmazzei
running Toyo AT3 305/45/22 on stock 22" limited wheels @ 38 cold PSI. No issues at all after trimming the wheel well a little. full turn left and right required minor trimming on both driver and passenger sides.
PaulieWalnutz
stupid question but do you guys get a spare tire same size ? What about having to upgrade brakes? I want to get these tires just want to be prepared
ekaz
No brake upgrades needed. If you get a spare in the same size, it might not fit in the stock location
