Fog light terminal size/number
U
User_21361
Guest
Does anyone know what size terminal the fog lights use? I tried searching but I know very little about automotive electrical connectors themselves.
I am preparing to wire a rough country light bar that has a DRL feature in the ADD bumper. The bumper doesn’t support fog lights so I thought about running the DRLs as fogs and using the stock housing to control the light. Then I can run a separate switch to operate the high beam. I would need a female adapter to the fog light terminal to wire to the harness so I don’t cut any factory lines. Any pointers would be appreciated.
Chanyote66
Hmm,
Are you wanting to connect into the factory fog light harness? or install wires from the BCM?
U
User_21361
Guest
Hmm,
Factory harness
Chanyote66
you can get an adapter for 9005/9006
that should be the correct socket.
