Mopar 2" Lift (level) for 2WD/RWD Trucks
jfred320
I think I've searched for long enough to justify asking for help, ha!
Dealer said part number 77072424AC only fits 4wd.
My question: Is there a Mopar 2" lift similar for 2wd/RWD trucks?
Looking to put on some 33/12.5/20s on my new wheels (20/9.5 -18). Would I need anything else to clear them without rubbing or cutting? Am I SOL?
Thanks in advance as any help is appreciated.
I come from the challenger platform so this is all a bit new to me!
The suspensions are the same between a 2wd and 4wd truck. The kit will fit, others here have installed it. Dealers tend to give a lot of misinformation regarding the mopar lift.
With the Mopar kit those wheels and tires will fit just fine. You might have a very slight rub in the front fender well but only on the inside plastic which can easily be fixed. You just get a heat gun and mold it out of the way. I ran 305/55r20 which is just slightly bigger than your 33x12.50. I had a 20x10 -25 offset and that was the only issue I had. I was only running a 2” level kit at the time.
Thanks I appreciate the info. I’m going to go this route.
