New Bilstein 6112's on '19 Billet Silver Laramie 4x4
Evo_KnEvo
Finally pulled the trigger today. Looked for a while after I bought truck in August of '19 and just put it off. Looks like I got basically 2.6" at circlip #8. Ground to fender before was 36 3/16". After install is 38 13/16". Front is currently 11/16" higher than rear and I'm sure it will settle from what I've read. May change rear springs and do the 5160's but I want to see where they do settle at. I have a long commute every day so shouldn't take long for them to. I also pull a couple boats so I'll be checking that out too. The plan is to get 35x12.50x20 Toyo AT3's and flush them with fender or maybe a 1/2" of poke. No More. Keeping the stock wheels. Hope this helps anyone that had all the questions I had.
Photo taken yesterday after getting home from work. 6112’s done on Monday. Top pic had about 5 miles on them. Bottom has about 170 miles on them. Settled a lil bit. Forgot to write down measurements. Ordered ORP for rear. May not use. Setting #8. They ride great so far.
Installed my ORP Rear springs today. On the bench they measured exactly 1.5” taller than my Non-ORP Rear Springs that also had 39,770 miles on them. Currently the fender to ground measurement, after about 15 miles is 39 5/8” for the rear and 38 5/8” for the front which is 6112’s @ #8.
Looks awesome!! Just confirm, just off road package springs in the rear?
Looks great. Where did you order the ORP springs from?
I have been trying to research, but this must mean that factory non-ORP shocks can be used with ORP springs without issue? Was thinking about Icons but I think these will fit my needs if I can do it without shocks, for now at least.
Thanks!
Thanks!
I ordered from moparoneonline.com
I do plan to order the 5100’s for the rear. I’ve put about 40+ miles on the stock non-ORP rear shocks since the install. No difference from what I can tell whatsoever. If in fact they wear out quicker because of the extra inch, I won’t be disappointed. They already have 39K on them. This truck doesn’t see off-road. I did that for 25 years traveling with Jeep’s. The CJ-7 variant. Just the occasional less than standard boat landing. Lol. Still though, for $21.72 per spring, kinda was a no brainer. Especially since from what Steve at Timber Grove tells me about the bags with 5-7 psi adding a little height to the stance. I didn’t want any taller of a spring. Do not want to be back to the 2.5” rake.
Wait you mean to tell me ORP springs are only 21.00 each?
Anyone have any idea where i can get 6112s right now?? Can't find them anywhere:mad:
Did you ever put your tires on? What does it look like with 35s?
Little update. Put on a set of Ridge Grapplers LT295/65/R20 (35.12x11.77) yesterday. Haven't put but a few miles on them so far. Should see 320 miles in the next 4 days with the work commute. Bilstein 6112's at #8 up front and ORP Springs in the rear. About 19K miles on the Bilsteins and ORP Springs.
Looks awesome, exactly what I want to do, how's the ride quality and fuel economy compared to stock? Noticeably different?
I've only driven it maybe 10 miles max since I left the tire shop. I'll get about 80 miles on them tomorrow with my roundtrip commute.
Been a few months since the post was commented on. Wanted to see how you were liking the ride compared to stock? Any issues with rubbing on that tire setup? I just purchased the 6112’s with carli rear springs. Debating on #7 or #8 setting.
looks good!
I have a 2” level up front and the 1” ORP out back as well.
Only chose 295/60R20 and I have a 1/4” spacer. I have a Laramie sport with the same wheels. Fwiw
