Inside door panel removal help.
Dave Smith
Greetings,
I've looked almost everywhere to find information on removing the inside door panel so I can apply some sound deadening material to the door's outside skin. There's a Youtube video that explains how to do this on a 2018 RAM but my 2020 DT is too different from 2018 in the video. The process looks and sounds fairly simple but I haven't actually attempted it yet. The issue that I can see is getting access to the bottom rear most window to detach the window regulator from the window. The video shows a simple clip to unhook and then pull up the window and lash it in the upper position with tape, then unbolt the lock. I don't see an access hole to get to the clip. I hope this makes sense. Any information on how to accomplish this task would be greatly appreciated.
Hope this helps---
edit--- just re-read your issue... --- look for the thread about adding passive entry, there is info there on removing all and getting to the 'inside' door skin..
-=FM45=-
There are access holes. You took the window down and you will see the bolts to remove. There are 2 of them. The passive entry thread has detail info. I did it when I installed my passive entry.
