Power steering fuse
AresSK
Hello. I’m struggling to find the power steering fuse in my 2019 1500 Limited. Reviewed the manual and I’m not seeing it. Could someone please point me in the right direction? Thanks.
Welcome to the forum!
I have not gone out to my truck to verify this is accurate, so take this with a grain of salt. Why are you looking for this fuse, power steering issues?
If you are looking at your power distribution center (fuse box under the hood), you'll see a row of silver/metal nuts/studs on one side. Those are not just power cables coming into/out of the box, they are also fuses. Towards one side, you'll see a 50A fuse right inside the box. On that corner, one bolt/nut in from the end should be the one for the electric power steering (EPS). It is N07 in the picture below. (Not my picture, I do not claim credit for it.) The documentation I have lists it as an 80A fuse.
The power steering fuse can "blow" when you are jumping or being jumped. I've come across it numerous times over the last 10 years and almost all of them were due to battery to battery connections. One was due to cheap thin jumper cables.
Thanks for the help. I was asking because of power steering issues - I was hoping it was as simple as a blown fuse.
Unfortunately, that’s not the case. I took the truck in to the dealer and they’re saying the power steering rack is dead and needs to be replaced.
I wish it was just a fuse.
Where is the actual physical 80 amp fuse to replace. I have taken this whole piece off
I replaced the whole part and still getting power steering codes
U0131. Lost communication. I only replaced all N fuses, part # below.
High Current Fuse Array - Mopar (68368852AA)​
"BCM lost communication with power steering control module" Could be either module or a problem with wiring. What symptoms do you have?
COMMUNICATION DIAGNOSTIC PROCEDURE
When Monitored and Set Conditions
NOTE: When performing this diagnostic procedure, additional diagnostic procedures may need to be performed. If directed, go to and perform the diagnostic test or procedure called-out in the test step. Failure to perform the additional diagnostic procedures, will lead to an incomplete repair.
When Monitored: This diagnostic runs continuously when the following conditions are met:
The Ignition is on.
The Battery voltage is between 9.0 and 16.0 volts.
Set Conditions:
When CAN Bus communication between modules is not available, due to certain conditions or circuit fault(s).
Possible Causes
SYSTEM OR ELECTRONIC CONTROL UNIT (ECU) VOLTAGE DTC(S)
SERVICE BULLETIN(S)
SOFTWARE UPDATE(S)
VEHICLE CONFIGURATION DTC(S)
COMMUNICATION RELATED DTC(S)
NON U-CODE DTC(S)
ECU POWER SUPPLY (FUSED B+ OR IGNITION) CIRCUIT(S) OPEN OR SHORTED TO GROUND
ECU GROUND CIRCUIT(S) OPEN OR HIGH RESISTANCE
CAN BUS CIRCUIT(+/-) OPEN OR HIGH RESISTANCE
POOR CONNECTION(S) AT CAN BUS ECU HARNESS CONNECTOR(S)
CAN BUS ECU
Diagnostic Test
1. CHECK FOR POSSIBLE CAUSES
This Communication Diagnostic Procedure is intended to provide the technician with a common starting point.
NOTE: For an in-depth explanation of the Controller Area Network (CAN) Bus system operation, (Refer to 08 - Electrical/8E - Electronic Control Modules/COMMUNICATION/Description) .NOTE: For intermittent communication issues, or if multiple communication related DTCs are set in other
Electronic Control Modules (ECUs), check the suspected ECU power and ground circuits, including at the body sheet-metal, for loose or poor connections. Performing a load test on these circuits will verify the circuit is capable of carrying the amperage needed to perform properly, along with confirming that excessive resistance does not exist in the circuit(s) being tested. For additional information on CIRCUIT LOAD TESTING PROCEDURES , (Refer to 28 - DTC-Based Diagnostics/Circuit Testing Procedures/Standard Procedure) . The vehicle communication systems may be diagnosed with the Mopar Scope, (Refer to 29 - Non-DTC Diagnostics/Communication - Diagnosis and Testing) .
Check Battery for proper State of Charge (SOC) and Charging System for proper operation. (Refer to 08 - Electrical/Charging/Diagnosis and Testing) .
With the scan tool, check all Electronic Control Modules (ECUs) for battery and ignition voltage related DTCs and record on the repair order.
Check for and perform all Service Bulletins that could be related to the customer complaint.
Check aftermarket accessories for proper installation. (Check for improper electrical connections and fasteners that may be contacting wire harnesses)
With the scan tool, check all ECUs for software updates that are related to the customer's concern. Update ECU(s) as necessary.
Check related wire harnesses for collision related damage.
Were any problems found?
Yes
Repair the problem as necessary.
With the scan tool, erase DTCs from the related ECUs and perform the appropriate VERIFICATION TEST. If a VERIFICATION TEST is not available for an ECU, perform the BCM VERIFICATION TEST. (Refer to 28 - DTC-Based Diagnostics/MODULE, Body Control (BCM) /Standard Procedure).
No
Go To 2
2. CHECK ELECTRONIC CONTROL MODULES FOR VEHICLE CONFIGURATION DTCS
NOTE: A Configuration DTC indicates that an ECU is not programmed with information that is specific to the vehicle (VIN, mileage, etc.). If an ECU is not configured properly, serial data communication failures may exist. The following list includes, but is not limited to, DTC descriptors that indicate a Configuration DTC.
ECU Configuration Mismatch - Not Configured
ECU Unable To Configure
Implausible/Missing ECU Network Configuration Data
Implausible/Missing Vehicle Configuration Data
Implausible Vehicle Configuration
Incorrect Variant/Configuration
PROXI Not Programmed (If applicable)
Restore Vehicle Configuration
Vehicle Configuration Mismatch
Vehicle Configuration Not Programmed
TYPES OF CAN BUS FAULTS
LOSS OF COMMUNICATION will set by an active receiving/reporting ECU on a CAN Bus network that detects no communication from another ECU on the same CAN Bus network. Insufficient power, ground, bus voltage, or inaccurate vehicle configuration will cause a loss of communication.
IMPLAUSIBLE MESSAGE will set by an active receiving/reporting ECU, when it determines the data sent from the active transmitting/offending ECU is missing part of the message, or the message is an irrational value over the CAN Bus.
MISSING MESSAGE will set by an active receiving/reporting ECU, when it determines a data message to be missing partial information when sent from the active transmitting/offending ECU over the CAN Bus network.
BUS OFF set by an ECU that has experienced approximately 32 transmit errors, this can be caused by ECU internal faults as well as external bus faults like shorts or plugging and unplugging test tools to the diagnostic connector.
PHYSICAL is only detectable by an ECU that has a transceiver that is able to detect shorts on the bus. If the ECU does not, it generally will set bus off faults due to shorted bus lines.
NOTE: A Vehicle Scan Report can be helpful if online/phone assistance is needed.
With the scan tool, generate a Vehicle Scan Report and record on the repair order.
With the scan tool, check all ECUs for Configuration DTCs.
Are any Configuration DTCs set?
Yes
Configure the ECU(s) as necessary in accordance with the Service Information Perform the appropriate VERIFICATION TEST. If a VERIFICATION TEST is not available for an ECU, perform the BCM VERIFICATION TEST. (Refer to 28 - DTC-Based Diagnostics/MODULE, Body Control (BCM) /Standard Procedure).
No
Go To 3
3. CHECK ELECTRONIC CONTROL MODULES FOR ACTIVE COMMUNICATION RELATED DTCS
Refer to the scan tool DTCs.
Are any Communication related DTCs active?
Yes
Go To 4
No
Go To 5
4. CHECK ACTIVE DTCS
NOTE: Diagnose Lost Communication DTCs (not to be confused with CAN Bus Off or Can Bus Performance DTCs) before diagnosing other CAN related DTCs.
Which type of Communication DTC is active?
Lost Communication
Go To 7
Implausible Data, Implausible Signal, Missing Message or Invalid Data
Go To 9
5. CHECK STORED DTCS
NOTE: Diagnose all Lost Communication DTCs before diagnosing other CAN related DTCs.
Which type of Communication DTC is stored?
Lost Communication
Perform the STORED LOST COMMUNICATION DTCS procedure. (Refer to 29 - Non-DTC Diagnostics/Communication/Diagnosis and Testing) . The vehicle communication systems may be diagnosed with the Mopar Scope, (Refer to 29 - Non-DTC Diagnostics/Communication - Diagnosis and Testing) .
Go To 6
6. CHECK THE ‘SENDING CONTROL MODULE’ FOR DTCS
NOTE: The ‘Sending Control Module’ is the ECU that the Implausible Data, Implausible Signal, Missing Message or Invalid Data is set against. Below is a list of some items (depending on vehicle configuration) a ‘Sending Control Module’ may provide as a bussed out to one or more “Reporting Control Module’.
Sensors
Adjustable Pedal
Air Temperature
Battery
Blind Spot
Crankshaft
Impact
Park Assist
Passive Entry
Rain
Ride Height
Seat
Sun
Tire Pressure
Wheel Speed
Switches
Audio
Brake / Stop Lamp
Door Ajar
Hazard
Heated
Hood
Ignition
Lighting
Multifunction
Power Seat
PRNDL
SOS Console
Speed Control
Are any DTCs set in the ‘Sending Control Module’?
Yes
Refer to the appropriate diagnostic procedure.
No
Go To 11
7. CHECK FOR MULTIPLE LOST COMMUNICATION DTCS
Choose the scenario that best describes the condition of the vehicle from the list below:
One ECU is reporting a Lost Communication DTC against a single ECU.
Go To 8
Multiple ECUs are reporting a Lost Communication DTC against a single ECU.
Perform the NO RESPONSE or NO RESPONSE FROM ECU diagnostic procedure for the ECU that is not communicating. (Refer to 29 - Non-DTC Diagnostics/Communication/Diagnosis and Testing) . The vehicle communication systems may be diagnosed with the Mopar Scope, (Refer to 29 - Non-DTC Diagnostics/Communication - Diagnosis and Testing) .
8. CHECK THE ‘SENDING CONTROL MODULE’ FOR COMMUNICATION
NOTE: The ‘Sending Control Module’ is the ECU that the Lost Communication DTC is set against.
Is the ‘Sending Control Module’ active on the bus?
Yes
Replace the Reporting Control Module in accordance with the Service Information
No
Perform the NO RESPONSE or NO RESPONSE FROM ECU diagnostic procedure for the ‘Sending Control Module’ that is not communicating. (Refer to 29 - Non-DTC Diagnostics/Communication/Diagnosis and Testing) .
9. CHECK THE ‘SENDING CONTROL MODULE’ FOR DTCS
NOTE: The ‘Sending Control Module’ is the ECU that the Implausible Data, Implausible Signal, Missing Message or Invalid Data DTC is set against.. Below is a list of some items (depending on vehicle configuration) a ‘Sending Control Module’ may provide as a bussed out to one or more “Reporting Control Module’.
Sensors
Adjustable Pedal
Air Temperature
Battery
Blind Spot
Crankshaft
Impact
Park Assist
Passive Entry
Rain
Ride Height
Seat
Sun
Tire Pressure
Wheel Speed
Switches
Audio
Brake / Stop Lamp
Door Ajar
Hazard
Heated
Hood
Ignition
Lighting
Multifunction
Power Seat
PRNDL
SOS Console
Speed Control
With the scan tool, check the ‘Sending Control Module’ for non-U-code DTCs that are related to the U-code that is set, or related to the customer complaint if the U-code DTC name is not clear about which signal is faulted.
Is a related non U-code DTC set in the ‘Sending Control Module’.
Yes
No
Go To 10
10. CHECK OTHER CONTROL MODULES FOR RELATED NON U-CODE DTCS
NOTE: IMPORTANT: Some ECUs simply pass information from one ECU to the other. In some cases, a U-code DTC may be set that implicates the “pass-through” ECU that sent the information. For example, if an Engine Coolant Temperature (ECT) Sensor DTC is set in the Powertrain Control Module (PCM), the HVAC Module may set an “Implausible Data from BCM” DTC because the BCM is the ECU that normally passes that information from the PCM to the HVAC Module. However, the BCM may not set any DTCs related to the faulted ECT Sensor because the BCM does not use the ECT information. In this case, the PCM ECT DTC should be diagnosed before the Implausible Data DTC. If you suspect a scenario like this, diagnose the non U-code DTC(s) before diagnosing any Implausible Data, Implausible Signal, Missing Message or Invalid Data DTCs. Below are some further examples of different sensors and switches:
Sensors
Adjustable Pedal
Air Temperature
Battery
Blind Spot
Crankshaft
Impact
Park Assist
Passive Entry
Rain
Ride Height
Seat
Sun
Tire Pressure
Wheel Speed
Switches
Audio
Brake / Stop Lamp
Door Ajar
Hazard
Heated
Hood
Ignition
Lighting
Multifunction
Power Seat
PRNDL
SOS Console
Speed Control
With the scan tool, check all other ECUs for non-U-code DTCs that are related to the U-code that is set, or related to the customer's concern if the U-code DTC name is not clear about which signal is faulted.
Is a related non U-code DTC set in another Control Module?
Yes
Diagnose the related DTC. Refer to the appropriate Diagnostic Procedure.
No
Replace the ‘Sending Control Module’ in accordance with the Service Information.
11. CHECK THE ‘SENDING CONTROL MODULE’ RELATED WIRE HARNESS CONNECTIONS
Disconnect all ‘Sending Control Module’ related wire harness connectors.
Disconnect all related in-line wire harness connections (if equipped).
Inspect wire harness connectors, component connectors, and all male and female terminals for the following conditions:
Proper connector installation.
Damaged connector locks
Corrosion
Signs of water intrusion.
Weather seal damage (if equipped).
Bent terminals.
Overheating due to a poor connection (terminal may be discolored due to excessive current draw).
Terminals that have been pushed back into the connector cavity.
Perform a terminal drag test on each connector terminal to verify proper terminal tension.
Repair any conditions that are found.
Connect all ‘Sending Control Module’ related wire harness connectors. Be certain that all wire harness connectors are fully seated and the connector locks are fully engaged.
Connect all in-line wire harness connectors (if equipped). Be certain that all connectors are fully seated and the connector locks are fully engaged.
With the scan tool, erase DTCs.
Using the Vehicle Scan Report, operate the vehicle in the conditions that set the DTC.
With the scan tool, read DTCs.
Did the DTC return?
Yes
If there is a history of this DTC setting multiple times, replace the ‘Sending Control Module’ in accordance with the Service Information.
No
Test Complete
