Anyone switched to aftermarket wheels using the stock 33" Duratracs?
SD Rebel
San Diego, CA
I'm thinking about doing a level and going with a set of 18" Method wheels or similar style, however I rather like my stock 33" Duratracs. I was considering just getting the wheels and then simply switching over to my stock tires (but black side out).
Has anyone here done that switch? I am worried that they may look too small with a level, even if the aftermarket offset pushes them out wider. If you did it, was it worth the effort to keep the stock 33" tires, how does it look?
And 1.5 spacers…Gonna go up in size when the stocks wear.
Looks good man, thanks for posting. I think I'll be doing the same, I'll switch to 34" tires after my 33" wears out, but considering how little I drive, that may take a while.
Methods, stock duratracs, and Readylift level here.
I think they do look small but my buddies say they don't.
Kept the stockers on mine as well and went with Fuel 18" x 9" wheels.
It was worth the effort to not spend $1900 on 35's with new 33's sitting on there at the time. I'm almost at 20k miles, so if these manage to last me another 20-25k I'll be ready for 35's by then. They look a tad small, but only you'll notice.
My exact thought process.
I want to put 35s on there but I too couldn’t part with the duratracs still in good condition. 18” Fuels w/ -12mm offset. Looks good but yes, a little small
Fuel Zephyr 18”x9.5” -12 offset. Stock suspension. Flipped Duratracs so that black letters were out. With the - offset the tires look way bigger.57A18C44-BB01-40DB-A1EC-9DBA147995BB.jpeg
Fuel Zephyr 18”x9.5” -12 offset. Stock suspension. Flipped Duratracs so that black letters were out. With the - offset the tires look way bigger.View attachment 94839
those wheels are looking good. can you tell us how far they stick out from flare?
i am installing bushwacker pocket flares and i thin i need more offset..
I had rubbing on the Mopar Mudflaps with 1.5” spacers installed. Little 5 min mod on the flaps and no more rubbing.
Wouldn't go up in size mess with the speedometer?
Absolutely, going from say 33" to 34" would result in about 1 mph lower indicated that actual. The error increases even more the larger the tire diameter.
Most people just live with it, especially since the Odometer becomes slightly inaccurate in their favor. However it can be fixed, using an aftermarket tuner.
