[Rear] ICON Shocks/Coils || [Front] ReadyLift UCA & 3.5" Spacer
brodieg
This is a hodge-podge suspension for anyone curious. Lol
I originally went with the ReadyLift 3.5" SST lift kit just due to spending a majority of my budget on wheels and tires.
With the ReadyLift I ended up getting a lot of stiffness (duh, spacers) and squeaking. Just ended up being displeased with the purchase in the end. My rear passenger side shock got a decently deep dent (no idea when), took the opportunity to upgrade to ICON Coils and Shocks for the rear.
Front: ReadyLift 3.5" UCA + Spacer
Rear: ICON 2.0 VS Internal Resevoir Shock + Rear 1.5" Dual Rate Spring
Images of measurements are attached. These are same day installed, no settling has occurred for the new shocks/coils.
After riding around with the ICONs... wow what a difference for the rear. Totally planted with super minimal body roll on sharp/quick turns and all of the stock "bounce" is gone. Really makes me want to just charge some front coiloivers to a credit card. LOL
The fox DSC coil overs set at 3 sure do ride great and would get rid of your spacers!
You would recommend fox for the front as apposed to ICON?
I thought icon only did a level worth of lift? If you did that then you’d still have to add a spacer. I would choose the fox coil overs and that’ll give you all the height increase you need without any ride sacrifice
