Nitto fits and Lomax covers
jaxplace
Just a little info on recent upgrades in case someone is looking for an idea of the fit. Installed Nitto Ridge Grapplers 285/50/22s on my stock 2021 Limited w/ air suspension. Seemed a good compromise from 33s or 35s...slight rub on front passenger wheel well only while in hard-lock reverse (Normal height and lower). Went under and literally folded the plastic up...no more rub! As for the Lomax...Great fit, very very little leaking. The only complaint on the Lomax is that the ordering process did not specify a build for my 5.7' bed with RamBox and MFT that came with the OEM BUG (black rails and tonneau). End result is that I needed to spend another $400 to get the lower model rails in order for the Lomax to properly install...after a month of shipping delays. All in the past now!
Hope this helps someone on the edge of decisions.
285/50/22. Half inch taller, 3/4 narrower than 33s.
I have the Lomax, installed it the first week when I bought back in Oct. I have been pleased with it. I garage it so haven't seen any leaks when driving around in rain. No issues with getting the correct one, have the same MFT and Rambox set up on my Limited.
I have also been considering that tire size and have to say it looks sweet on the ride. I'm not looking to lift the suspension but want a meatier tire on the 22s.
Your truck looks great, were these pictures taken in the normal ride height position? I have a Longhorn without the air supension and trying to figure out if I would need a level with these tires to achieve the same stance.
