Largest tires on Stock Rebel suspension and wheels
I've seen a lot ask this question and I was wondering too a few months ago, about what the largest tire you could fit on a stock Rebel. I ended up putting Cooper Discoverer AT3 XLT 285/75 R18s on my 2020 Rebel. These are 34.84" tall and no rubbing whatsoever. View attachment 92651View attachment 92652
Awesome! How do you like that size on the Rebel?.. How’s it drive?
I love the drive on it and could tell the difference in height while driving even though it's basically just 1" taller than stock. I also like the beefier look to them. Getting a little better mileage too on my ecodiesel with them due to more distance per revolution.
Looks great. Will that size work with air suspension?
Intereresting
Stock spring suspension?
Have you had a chance to wheel it a little bit yet?
This is very interesting, I have a set of Falcon terraflex shocks, I'm running it in the medium setting. I want to say it lifted it a little less than an inch in the front, and I'm starting to think I can probably fit 34.3" tires in there...
Was looking at those exact tires and didn't want to lift right now. The weight saving on those vs the ridge grapplers was huge. I do a ton of highway miles. Thanks sir.
Look nice, do you level kit ? Or spacer wheels ?
I also went with 285/75/18 tires. I have the Falcon shocks set to level with an additional 1/2 wulf spacer in the front. No rubbing at all. I went with .75" spacers in the front and 1>00" spacers in the rear.
I put about the same size tires on mine, no issues thus far. No rubbing at entry exit, or otherwise. I have not taken it off road since installation. But it is right in line with what I got fomr the folks at the dealership when I asked them the largest size tire I could put on my truck.
Intereresting
Yes mine is stock spring suspension, no spacers or leveling kit. Have driven them 7,000 miles now and have had no issues
Hi DieselRebel, looks great and I just asked about these exact tires on another post. Does your rebel have the air suspension or the 1" factory lift? Just checking, because i think the air suspension gives a 2nd inch of lift.
i got 305/70/18 on my reb with stock everything 😂 but why do your tires look so much more beefy
So you went with Falcons and a 1/2" Wulf in the front? Did this level the truck? What height did you get out of the Falcons over stock? Full 2"? Did you put a lift in the back?
The factory lift with the Rebel/offroad package, coil springs, no air suspension
Now that you have a few miles on them, how's the road noise vs the stock tires? My factory tires are getting a bit noisy already even with rotation every other oil change.
Not any major road noise that I have observed. They are all terrains, but tread pattern looks less aggressive than the goodyear duratracs that came stock on my Rebel.
