Take a look at wet Okole. I absolutely love them.
I hate neoprene seat covers. Just not my thing at all. What I like about the coverking is the dense nylon material. It will last a long time. I knew because of the material choice, it would be a bulky fit, just kind of annoyed at the back seats.
Honestly, if it wasn't for the side airbags, I would have gone with the universal fit Cabelas Trail Gear.
How are those Recons treating you now? I’m thinking about getting some, just can’t get past that 90 warranty.
Great, no issues. Fitment is good, the light out put is slighty dimmer than the factory led ones.
Nothing happened other than the sound is amazing!!
Sound clips do not do it justice.
so true! Some exhaust systems make noise, and others make SOUND. Borla makes SOUND. At idle, it's just enough for the car guys to turn their heads and smirk. At full throttle, soccer moms run and hide.
What are your thoughts on the sprint booster? I just put the ram airflow on my 2021 laramie.
I have the pedal commander and it’s been pretty fantastic so far. Had it on since July of ‘19. Various levels of throttle sensitivity.
Continued "photoshopping" wheels onto it to see if I will ever find a set that I like. So far I really liked the Venomrex 601's but don't like that the offset only comes in +15mm or 0mm. I like these Black Rhino chase wheels quite a bit so far. Badging is black now so it would blend a bit better than it does in this picture. Thoughts?
Can you describe your choice of wiring technique for the LED strips? I have mine waiting to install.
After installing the led strips under the bed rail, I ran the wires through the oval shaped hole that goes between the taillights and bed area. Then I just tapped into the existing Red and Black wires connected to the factory cargo bed lights. Don't tap into the white w/tan wire, I have heard some folks have flickering issues when tapping into that wire. The kit I got from Amazon had a push button switch included. I just stuck the switch under the bed rail. Now the lights come on the same as the factory cargo lights, or I can leave them in the off position if I don't need them on.
These Threads always seem to be fun and keep us all spending money so chime in and lets get the ball rolling....
Put new decal on back window on my Ram 1500
  • Nels
