Boost Monkey
 - Sep 23, 2019
No, last I checked the Ram 1500 springs are progressive.
So you are 100% confident that both the front and rear coils are progressive? If so, are they dual rate progressive or full progressive?
Dual rate progressive springs are far more akin to linear springs. Almost all of the bump/droop travel will be within one of the two rates and, trying to word this as least confusing as possible, all compression/rebound within the full range/length of each rates' section of the spring with be linear. Typically the second rate part of the spring acts like an integrated helper spring. This all means that if they are dual rate, compressing the spring to change height with have a pretty minimal impact (if even felt at all) on the ride stiffness.
As for fully progressive, yeah that's different but although I could easily see the rear coils being fully progressive (serving a strong role in load management), I have a harder time believing that the front coils are fully progressive. Linear rates give you predictability in the suspensions' rebound/compression performance when handling bumps... Typically what you want on the steering end of the chassis.
