Who's running Eibach Pro leveling struts?
I just got my eibachs today waiting on my RC UCA then. I’ll be doing the same level.. did you also do the rears in eibach
Nope didn’t touch the rear.
Sharp truck! What are you hub to fender measurements now?
I’ll have to check. I don’t remember off the top of my head.
Would love to know the measurements also. I have an orp truck and when I was ready to purchase Bilstein seems to have gone on a national back order. So came back here to do some research on these. I plan to lift at 1.8" in the front and swap the rears. I'd like to add a 1" coil spacer to the rear as well to keep a little rake. Thoughts from guys with the orp springs? Think it is necessary?
I only tow a 8x10 trailer so I didn’t have much need for the rake. I am adding the timber grove bags though. Had the airlift 5000’s on my 4th Gen but don’t feel like cutting anything on this one.
1.8 with ORP. Rides just the same as the 5100’s on my 4th Gen.
Looks great! Did you swap UCA’s or still running factory?
I had Zone UCA’s I never installed on my 4th Gen. Bought them brand new for $200 on Craigslist. So I put them on when I swapped out the motofab spacers for the Eibach’s.
Finally got the Eibachs all around..
Nice! What height setting up front and any lift in the rear? Looks like you have the ORP springs right?
And How’s the ride??
The 3rd clip so 1.8 in up front and no mahjong but the ORP springs in th back and every thing still feels factory smooth i only have a few miles on it
That looks REALLY good. What size tires?
Thank you! Tires are 285/65r20 the tire reads 35x11.5 but they are a 34in tire.. fits perfect no rubbing on normal conditions but full lock to the left in reverse something hits I can’t find what it is yet
Check the the mudflap to the rear of the tire, that’s where it always rubs.
Still love mine.
I have that same truck and thinking about the Eibach setup. What are your measurements center of wheel to fender? How do you like the ride?
I don’t recall but it was like 42 or 43” if IIRC from pavement. Perfectly level. Ride is excellent. Highly recommend the Eibachs.
I called to see if their struts could be put on my 2022 Rebel and they said they have not tested them on a Rebel. I can't imagine my suspension is any different than those who are running off road springs and Eibachs. Was going to order a set but decided not to, tech at Eibach kinda talked me out of them.
That’s odd. Can’t see why they wouldn’t work.
