Purchasing a new truck. Need your help!
7amada
Hey Everyone. Need the help of all you Ram gurus here ...
I have decided to purchase a new 2021 truck and have made my decision on a Built to Serve in either the ceramic gray or anvil color.
I want to take advantage of the 0% APR and 84 month financing so I only have till May 3rd. I have looked allover my state with no luck.
QUESTION, what would be the best way to try and find a 2021 ram built to serve in either anvil or ceramic gray. not picky about other options. Anywhere in the nation is fine.
Any and all help is appreciated. THANK YOU :cool:
Fatherof3
Ontario Canada
Would google “ new Rams for sale “ work ? Up here I’d use auto trader .
2020RAMLTD5.7
NYC
Hey brother. Go to Ramtrucks.com and do a search. Go to the search filter and clear everything, then check off built to serve in the packages tab. And make search distance the max which is 250 miles. Or go to your nearest RAM dealer and they should be able to search inventory in the whole country. GOOD LUCK!!
jimothy
5thGenRams Supporter
Atlanta, GA metro
By the way, 0% for 72 is the max you’ll get on a Ram, at least around my parts.
7amada
Yeah I tried that, nothing within 250 miles. wish it gave you the option to search nationwide
millerbjm
St. Paul, MN
I just did the 250mi search from St. Paul, MN and there are only tank and flame red on lots here. I still had Anvil as an option to check but ceramic grey wasn't even listed anymore.
7amada
That is what I get too. Can only search for anvil and within 250 miles only flame red and tank color.
jimothy
Atlanta, GA metro
Ram website says ceramic grey is sold out, which explains why you can’t search for it. But there could be one on a lot somewhere; Autotrader might help you find it.
wallyuwl
Do you need a truck right now or could you do an order? Incentives should be better in summer (but worst case you can lock-in current incentives and take the better of now or when the truck is delivered) and you are close to Aaron to order from in Louisiana who has near the best prices in the country.
SCasey89
The ceramic gray BTS trucks are no longer available. They were released last year, and can’t be purchased any longer (unless used).
You might be able to still find an Anvil unit. I think there’s a dealer or two in California that may still have one. And the only reason a dealer would still have one at this point is because they are unwilling to negotiate on price.
Oh, and the Ceramic Gray trucks were 2020s, not 2021s.
2020RAMLTD5.7
NYC
I'm using zip code 11426 which is Queens,NYC. There's 85 built to serve within 250 mile radius, however only 1 that's NOT red or tank green. I attached screen shots. It doesn't have any dealer info,not sure what that means.
SCasey89
7amada
Cant get Anvil or Ceramic Gray when ordering, I tried. Unless of course I did something wrong
7amada
Thank you for that info. gonna do a few zip codes to check them out
7amada
SCasey89
No, you didn’t do anything wrong. It’s just the nature of the Built To Serve Package.
The Built to Serves are a limited edition. When all said and done, Ram will have offered five releases for each branch of the armed forces. The number of units produced per color, per release varies, but it’s been about 1,000 units each.
Ram has done one release at a time, and once the total number of units of that release are produced, that is it. The colors aren’t available anymore.
So in the case of the Ceramic Gray (Summer/Fall 2020 release) and Anvil (Winter 2020/2021 release), all of those trucks have been produced and BTS trucks in those colors will not be made again.
Ram is currently on the fifth, and final, release of the BTS lineup. The final release is for the Coast Guard and includes the colors Bright White and Spitfire Orange. Once this final release is produced, there will be no more BTS trucks produced.
7amada
So in the case of the Ceramic Gray (Summer 2020 release) and Anvil (Fall 2020 release), all of those trucks have been produced and BTS trucks in those colors will not be made again.
What about this VIN.
It is built to serve, in anvil and is 2021
  • 1C6SRFFT4MN562373
